It is currently Mon Jul 28, 2025 5:15 pm
 Post subject: Bondo? For pore fill?
PostPosted: Fri Jun 19, 2020 9:04 pm
Last Name: Livermore
State: Minnesota
I did a little body work on a vehicle today. Parts store sold me fas acting bondo. 25 minutes from application to sanding.
Has anyone tried this for pore fill yet?
I will be running some tests to see how it works and holds up.
PostPosted: Fri Jun 19, 2020 9:23 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
This is a joke right? If so Padma would be proud. In any case I would avoid the pink.
PostPosted: Fri Jun 19, 2020 9:45 pm
State: Minnesota
I did search the archives and didn’t see anything since tha Padma was around.
No joke. Very curious.
Why not? (Other than the pink, I’m sure it could be dyed black or brown.)
PostPosted: Fri Jun 19, 2020 10:36 pm
It would impact the tone and the thing would sound like a 57 Chevy :D That's not a bad tone at all BTW.
My read back then in "DP" times "during Padma" on the OLF was that Padma wanted us to be more open minded about what you could use for pore filler. When I was the first moderator (and maybe the last) that the OLF ever had Padma once suggested that certain bodily fluids make great pore filler. I remember it well because it was the only time I ever considered editing or deleting a post. Lance's marching orders where that he wanted his seven year old to be able to read the forum.
Anyway sure Bondo why not and Padma IIRC had used it before and was not just suggesting it. He painted too so he likely dyed it Dave as you have suggested. Seems to me that it would be no more harmful than epoxy which is what I always used.
Lastly one of the Dan Erlewine books on finishing guitars shows Dan using Bondo to smooth out electric bodies.
PostPosted: Fri Jun 19, 2020 11:24 pm
I have great respect for Dan, but his every word is not always gospel in my shop.
PostPosted: Fri Jun 19, 2020 11:28 pm
Test it on scrap, all the way to applying finish. See how "pretty" it is.
PostPosted: Fri Jun 19, 2020 11:34 pm
State: Minnesota
I’m not trying to be heretical here. The perfect pore fill is an oxymoron as we all know.
This stuff is nasty smelling so it does have a down side. But a pore fill that is ready for sanding in 25 minutes might be just the ticket.
PostPosted: Sat Jun 20, 2020 6:30 am
http://cms.mohawk-finishing.com/catalog ... ictNbr=884
Mohawk makes a wood colored (oak) bondo that I have used for furniture repair. It can be colored with pigment stains and probably the ultra penetrating stains (which being alcohol based might also thin it). I've never used it as a grain filler, but it should work as well as any other Bondo product, and starting out as a "wood color" might have some advantages. I used the white colored hardener with it rather than the red.
Minwax may offer a similar product (I've never used it) which may be more available.It doesn't have quite the wood color, but if you are coloring it anyway that might not matter.
https://www.youtube.com/watch?v=Gc_EN7SYCPY
My father had a used car lot, and I occasionally did some body work for him (minor stuff). Bondo was good for small fills and as long as you have impermeable material behind it (metal, fiberglass, etc.) and paint on top of it so moisture can't be absorbed it can make a lasting repair. If water can get to it it will bubble and the paint will craze and crack.
PostPosted: Sat Jun 20, 2020 9:19 am
First name: Stephen
Last Name: Foss
State: Colorado
Folks,
I have used bondo to repair a semi-rotting window trim. 10 years on and it's still just fine; but with paint over the top and not laquer.
A better choice for guitars is drywall mud. Tints easily, sands easily, goes in those pores easily. Dries in 30 minutes, ready for sanding and the next application (takes 3 times).
PostPosted: Sun Jun 21, 2020 9:45 pm
First name: John "jd"
City: Santa Barbara
Whatever gets the pig clean...
PostPosted: Mon Jun 22, 2020 12:25 am
https://www.princevaliant.org/guides/wa ... index.html
I have a vague recollection the above product was discussed before.
PostPosted: Mon Jun 22, 2020 6:10 am
wbergman wrote:
https://www.princevaliant.org/guides/waterPutty/index.html
I have used this and find it is pretty much the same as the drywall mud.
PostPosted: Mon Jun 22, 2020 8:45 am
I think there are people using drywall compound too. I don't see why Bondo would not work but there are better alternatives, as mentioned bondo stinks pretty bad. On the current two I am building I am trying Aqua Coat for the first time it's pretty darn good stuff if ya ask me.
That water putty is gypsum based so it might not work so well with water based finsihes?
PostPosted: Mon Jun 22, 2020 4:53 pm
One the one guitar I've built so far I had success using sawdust and shellac to do a pseudo pore fill. The neck came out prerrt smooth and nobody really noticed anything off with it.
I keep seeing the name Padma pop up. But I can't ever get the nerve up to read those old posts. Might be for the better lol
PostPosted: Mon Jun 22, 2020 7:40 pm
Are you sanding back to wood with aqua coat?
PostPosted: Mon Jun 22, 2020 8:02 pm
I use Aqua Coat and yes, I sand back to the wood.
PostPosted: Mon Jun 22, 2020 10:21 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Hey Dan,
Duh Padma was cool. Especially for us old guys. He made some adventurous objects' de art. bliss
PostPosted: Wed Jun 24, 2020 11:46 am
D'ah Padma:
https://www.youtube.com/watch?v=QeYSSD0H6O4&t=23s
https://www.youtube.com/watch?v=kygZhKh7f_s&t=5s
https://www.youtube.com/watch?v=JbV-iuUZwn8
PostPosted: Wed Jun 24, 2020 2:18 pm
Yes I do sand back to wood too. It really is good stuff. Dries to be sanded in like 45 minutes.
PostPosted: Thu Jun 25, 2020 5:36 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
There is Bondo and there is spot filler. Bondo is 2 parts you mix. Hard to sand. Spot puddy comes in a tube you just wipe on. Easy to sand and is similar to drywall joint compound.
Jason Moe
LaCrosse WI 54601
PostPosted: Wed Jul 08, 2020 2:52 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Whatever happened to the Padman? That guy was a hoot.
PostPosted: Wed Jul 08, 2020 4:37 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
NO NO NO NO NO!!!!!!
https://www.blogger.com/blogger.g?blogID=5396679055777605096&useLegacyBlogger=true#editor/target=post;postID=1444068106407428690;onPublishedMenu=posts;onClosedMenu=posts;postNum=16;src=postname
Brian
Users browsing this forum: Mike Thomas and 14 guests
